Selected radio in radio group not inserting value
Thread begun 5/10/2012 3:49 pm by Paul | Last modified 5/11/2012 1:45 pm by Paul | 1483 views | 4 replies |
PaulBeta Tester
Im using Security Assist to build a registration page with form field validation.
All is well apart from the radios are not passing the selected value ( 1 or 2) to mysql DB on form submit.
Page attached.
Any ideas?
Thanks, Paul.
in the insert record behavior, for a number of columns you are using the validated entries binding.
The validated entries bindings only have values when the form fails validation, you need to use the binding from the form collection, not the validated entries.
PaulBeta Tester
Thank you for quick reply Jason.
That resolved issue.
However, I'm left with the UE not sending after the form successfully inserts.
In the same attachment of my previous post, are you able to see what maybe preventing a send?
I have amended the 'To' email to
<?php echo ((isset($_POST["UsrEmail"]))?$_POST["UsrEmail"]:""); ?>
Of course i only want UE to send if the form validates successfully and inserts the data into mysql
Thanks, Paul.
you have the insert record behavior set to redirect to the thank you page after the record is inserted, this happens before the email is sent
update the insert behavior and remove the redirect.
PaulBeta Tester
:eek: Doh!
Thank you. Resolved!
