Drop down lists / menus
I set up my preset to produce a select list (1 column tall) that connects to a recordset for some of the fields. It did not work as no list was produced by the wizard.
An input for a list was shown in the code, so I populated it with the data from the recordset, so that the list worked, and when I ran the code, all that appeared for that field in the database was the word Array - not the field value from the array.
I then bound the field in the insert record server behaviour to the recordset field and thought that the problem was solved. However, on closer inspection, no matter what selection I make, the first item in the list is always stored in the database.
The name always appears in the code like Registration_group_fieldname[]
Does this need changing, or is there another reason for the problem?
