js Error message on DW CS6 load
Thread began 5/08/2012 5:38 am by Nature Photographer | Last modified 5/10/2012 1:17 am by Nature Photographer | 1364 views | 4 replies |
Nature Photographer
Hi I just upgraded to DW CS6 and reinstalled the WA extensions but when I start DW I get a js error (see attachment) I've cleared the WinFileCache.dat file but still the error message appears on loading DW.
Also attached is the file in question showing line 390
Thanks for your assistance.
CSS Form Builder is not compatible with Dreamweaver CS6, we have recently released the Data Bridge and Design Extender consolidation projects which replace the stand alone extensions. the Consolidation projects are compatible with DW CS6, but the stand alone version will take some time to be updated. We strongly recommend anyone moving to CS6 also update to Design Extender and Data Bridge.
Nature Photographer
  CSS Form Builder is not compatible with Dreamweaver CS6, we have recently released the Data Bridge and Design Extender consolidation projects which replace the stand alone extensions. the Consolidation projects are compatible with DW CS6, but the stand alone version will not be undated, the stand alone version will only work in the originally supported Dreamweaver Versions.
Hmm that's not good then!!!! Another $400 to upgrade so I can use extensions I already own.
Jason what other standalone webassist extensions won't be compatible with DW CS6?
You would not have to pay $400... the policy is to take 100% of previously purchased extensions included in the integration off the integration price up to 50% off the new extension, so you would likely get 50% off based on your order history.
Also it includes a major update to Data Assist which is well worth the additional cost alone.
Jason misspoke in saying that other extensions definitely won't be updated. Some may be updated if necessary in the upcoming months. The next extension we are going to update will be eCart and then we will evaluate what else needs to be updated and in what order based on user feedback. We do strongly suggest upgrading to Design Extender and Data Bridge since we have around 30 stand-alone extensions it will take some time to test and update them each individually.
Nature Photographer
Thanks Ray, wasn't meaning to sound begrudged, it was just when I looked in my upgrade centre...each of the two new extensions were going to cost me $200 each, (yes there are a couple of extensions I don't have and probably would never use) but as I only am a owner operator of a website, I don't use the tools often and it becomes a large expense for me to upgrade for little overall use....Hope you understand where I'm coming from. I understand you're in business and that’s fair enough.
Thanks all the same.
