yourcompany@yourcompanyserver.com
Thread began 5/03/2012 2:40 pm by templemedia365477 | Last modified 5/11/2012 3:31 pm by Jason Byrnes | 1022 views | 11 replies |
templemedia365477
Hi - the email generated from forgotpassword.php shows yourcompany@... in the return address line. How to change this setting??
Also - where is the main CSS to change margins, remove border, etc... Thanks!!! ttt
on the forgot password page, double click the Security Assist Email Password server behavior and go to the Email Settings tab.
the css files are located in the webassist/forms/ folder
templemedia365477
thanks
all good, ttt
templemedia365477
not all good
Hi, I changed the email address setting in Server Behaviors and am now getting this error:
forgotpassword.php
Warning: Missing argument 6 for WA_SecurityAssist_Definition(), called in /hermes/waloraweb012/b1020/as.seminolefeed/forgotpassword.php on line 25 and defined in /hermes/waloraweb012/b1020/as.seminolefeed/webassist/security_assist/mail_php.php on line 34
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /hermes/waloraweb012/b1020/as.seminolefeed/webassist/security_assist/mail_php.php:34) in /hermes/waloraweb012/b1020/as.seminolefeed/webassist/security_assist/mail_php.php on line 239
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /hermes/waloraweb012/b1020/as.seminolefeed/webassist/security_assist/mail_php.php:34) in /hermes/waloraweb012/b1020/as.seminolefeed/webassist/security_assist/mail_php.php on line 239
Warning: Cannot modify header information - headers already sent by (output started at /hermes/waloraweb012/b1020/as.seminolefeed/webassist/security_assist/mail_php.php:34) in /hermes/waloraweb012/b1020/as.seminolefeed/webassist/security_assist/helper_php.php on line 133
FYI, I also refreshed the template to add a link to the header, if that makes any difference...
templemedia365477
email generated
Even though it gives the above error, it does generate the email properly addressed, but with nothing in the email body to allow them to retrieve their password or set new one - how do we do that?
Send a copy of your forgot password page please so I can take a look at the code.
templemedia365477
forgot password problem
tried to attach the .php but the format is not supported. Can you see it at forgotpassword.php?
nothing attached.
compress the page to a zip archive and attach the zip file please.
templemedia365477
zip
duh - here's zip...
forgotpassword.zip
this line:
$WA_MailObject = WA_SecurityAssist_Definition("yourmailserver.yourdomain.com","25","","","");
should be:
$WA_MailObject = WA_SecurityAssist_Definition("yourmailserver.yourdomain.com","25","","","","");
to set the email body, edit the Email Password behavior, and go the Email Settings tab. in the Message section, you set the email body.
