error with DW CS5 with Data Bridge
Thread began 4/30/2012 4:58 pm by hdavis136190 | Last modified 5/02/2012 5:59 pm by jbeckman307551 | 2897 views | 8 replies |
hdavis136190
I installed the new Data Bridge. After removing the below list.
CSS Button Styler, CSS Form Builder, DataAssist, Digital File Pro, Dynamic Connections, Dynamic Dropdowns, Dynamic Web Charts, Form Toolkit, HTML Editor, Image Resizer, SecurityAssist, Universal Email and Validation Tooltips for Spry.
If you own Design Extender, please install Design Extender 1.0.4 or newer for full compatibility with Data Bridge.
I also saw the errors that others have about ecart, so I removed ecart, then those errors where gone.
then I opened a php file, and entered WebAssist->Database->DataAssist Pages menu,
I am running DW CS5 on a MacOS X 10.6.8, I can do a bind to the Database, look at all tables in Database. Any help would be great. Thanks.
the first is just a note that the Database connection needs to be uploaded to the server, you can ignore that one.
for the second error, have you tried deleting the Dreamweaver cache file?:
elizabeth130596
Data bridge... where is it?
Hi - I just bought the Super Suite for DW CSS 5. Data bridge looks helpful. I checked What's Included and see Databridge. But where is it? There are so many extensions that need to be NOT installed, that I cannot determine where is the best place to start so I don't have to rip out my entire configuration.
So... once I find Data Bridge, what else goes in? Data Assist? Design Extender? What else? and What else needs to be not installed/uninstalled in order not to have conflicts?
thanks,
elizabeth
the the extension install tips thread for details:
showthread.php?t=24005
Now that Data Bridge is out... if you own all of our extensions you should only have to install:
eCart, Design Extender, and Data Bridge
all of the other extensions (except for the free ones) are combined into those three products.
jbeckman307551
Are there any non-free plug ins not rolled into the others?
In addition to eCart, Data Bridge, and Design Extender, I still have Cookies Toolkit, SiteAssist Professional, Surveyor, and Theme-it. Are any of these rolled into the others?
Also, it took 3 browsers before the darn captcha appeared (failed on Firefox 10 and Safari 5.5, finally worked on Opera).
Surveyor and Theme-it have been discontinued for now, so they haven't been integrated (but they may resurface in a future update).
Site Assist Pro was replaced by Site Sculptor and is included in Design Extender. Cookies Toolkit is included in Data Bridge.
jbeckman307551
Thanks. You might want to put that in their descriptions - I noticed some of the other plug ins have what supersedes them listed.
hdavis136190
The Doc talks about CS3 and CS4, I am running CS5, the file it says to look for, is not found, I also used spotlight to search for it, with the result being none.
