Insert / Update Behaviours from older version
Thread began 4/29/2012 1:35 am by Ian S | Last modified 4/30/2012 10:50 am by Jason Byrnes | 779 views | 1 replies |
Ian S
Hi WA,
I am just having a play around with Data Bridge and seem to be having a problem where previous Insert and Update behaviours are no longer showing in the Server Behaviours window. I am having to retype the comment above the behaviours for it to display in the Server Behaviours Panel (//WA Application Builder Update to //WA DataAssist Update)
Delete Record behaviours do show though.
Also, once you are able to edit an existing behaviour from the prior version, on the update behaviour it adds the new helper file but leaves the old helper file on the page. This doesn't happen on the Insert and Delete (it works correctly on these)
Cheers
Ian
Ian S
This post has been deleted.
I have logged this in our bugbase so we can correct it, we should be releasing an update soon, hopefully with in the week to fix this problem.
