Security Assist Not Adding or Editing User Table
Thread began 4/25/2012 3:37 pm by janet259027 | Last modified 4/26/2012 12:49 pm by Jason Byrnes | 1311 views | 5 replies |
janet259027
I just used the Security Assist 'Create Security Pages' option and generated the five pages: login.php, logout.php, forgotpassword.php, registration.php and userupdate.php.
The login.php, logout.php and forgotpassword.php work fine. The userupdate.php displays the information for the logged in user, but when I click the Update button it tries to redisplay the userupdate.php page and I get the message that indicates there is a programming error.
The registration page gives me the same type of error when I click the register button.
I have made no changes to the pages generated by Security Assist.
add the following code to line 1 of the userupdate.php and registration.php files to turn on error reporting:
error_reporting
(E_ALL);
once we know the error that is occurring we can begin troubleshooting it.
include a copy of those page in a zip archive with your reply
janet259027
Hi Jason,
I attached the zipped file you wanted and there is a .txt file that has the errors for both the registration.php and the userupdate.php.
They are both the same error: Fata error: Call to undefined function WAValidateUnique()
email to web assist 4-26-2012.zip
this happens if security assist is not the last extension installed.
see this thread for extension install tips:
showthread.php?t=24005
and this thread for an updated copy of the webassist/form_validations/wavt_scripts_php.php file to correct the problem:
showpost.php?p=106073&postcount=14
janet259027
Is there a more recent list of what extensions are bundled?
Hi Jason,
Thanks for the info. I just wondered if there is a more recent list of the bundled extensions since that thread was dated in 2006. I only ask because I have the super-suite and there are so many extensions I hate to install them in the wrong order. I just recently purchased the CSSButtonStyler extension and I don't know if that will cause a problem if I install some of the other CSS extensions.
I just uninstalled all my extensions and want to put them back in the proper order. I'm assuming I should always answer Yes to All to the prompt when it finds duplicates?
you're looking at my join date, the thread was started in 12-06-2011, 01:37 PM, and has been updated since with the most recent information.
