Unable to upload images
Thread begun 4/23/2012 7:50 pm by rik.forgo | Last modified 8/06/2013 8:53 pm by Ray Borduin | 4914 views | 10 replies |
rik.forgo
PowerCMS was working just fine for my client and then, sometime earlier this month the upload capability just stopped working. I haven't changed a thing, and no one else has access to the code. Perhaps it was something Dreamhost did. In any case, I need to get this function working again or I'll be spending a lot of time uploading images for them via FTP.
If it helps, in Chrome 18 the Kai editor doesn't even load. In IE9 it loads but there is no upload/find file button. I just get a grayed out cancel button. My client can't upload either and is experiencing the same issue. Is there a fix for this?
JamieEff
Hi Jason
Was there a fix for this as I have been using Chrome (20.0.1132.47 m) and when you click on 'browse server' a window opens (and is showing in the taskbar) but wont show at all...not even when you minimise all other windows.
Jamie
jeffsure
I've run into the same issue, unable to upload images. The Browse Server window opens, and all the buttons are there, I can select the file I want to upload, and click upload, but nothing happens. Any thoughts as to what's wrong?
zuffster370186
Jason, I am having the exact same problem as jeffsure. The file manager opens and lets me browse the server or files on my harddrive however when I select an image and hit the 'upload' button, the file does not upload and it tells me "No File Selected".
I am using IE8 & 9.
zuffster370186
Jason, I am still waiting on a response to my comment #7. Thank you
sean366869
Upload button missing
Has this been resolved? I have the same problem with Internet Explorer 8. No upload button, just a cancel button which does nothing.
Do you have the latest version of Data Bridge installed? This issue was fixed in data Bridge
When adding the HTML Editor instance, make sure that you select a preset that has the file manager enabled.
