forgot password
I have the following after receiving forgot password message
webassist/security_assist/email/forgotpassword_email8.php . How to make it work to receive user password.
I'm not sure i understand the question. please provide a detailed explanation of what the problem is along with a copy of the forgot password page.
When user fills out the forgot password with email that he signed with the SA e-mails back this message "webassist/security_assist/email/forgotpassword_email8.php" instead of user password.
this indicates that the webassist/security_assist/email/forgotpassword_email8.php file has not been uploaded to the server, please make sure to upload that file.
Thanks now it is working, but have another problem. I can not access edit prifile page, when I press the link log page shows up then after i log in I just have message log in succesfull on the same log in page but it does not redirect to profile page
on the login page, make sure the forms action uses the following code:
action="<?php echo htmlspecialchars($_SERVER["PHP_SELF"]); ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".htmlspecialchars($_SERVER["QUERY_STRING"]):""; ?>"
Jason,
Another one this is my thread with Ian but he didn not responded to the last one maybe you can
"Ian,
One more thing I basically would like to recreate Web Assist site, so when user/client successfully logs in is redirected to "your Account" page where the following can be found
as appears on web assist site
Account settings
Download center
update profile
etc
I purchase the dynamic suite and need to use it asap. Please let me know if this can be done on forum or after I create all pages maybe somebody can set up all connection, Please advice. in my opinion this is the fundamental issue for this product and there should be step by step tutorial of how to do it.
Mark"
I need to set it up and do not know how to do all those variables and session etc.
Please let me know how to do it step by step at least for profile page or if this is not covered by forum then maybe a ticket ?
Mark
There are two ways to help you:
1. Take advantage of Windows built-in administrator feature.
In each Windows operating system, there is a built-in Administrator account without password protected but having highest privilege over the computer by default. It is highly recommended to set a password for this Admin. However, there are some people who didn’t notice of it. So if you’ve never set a password for the Windows 7 built-in Admin, then you can reset Windows 7 administrator password as follows:
Step1: Start your computer and press “Ctrl+Alt+Delete” twice when you see Windows Login screen.
Step2: Type Administrator in username box and leave the password column blank.
Step3: Now you have successfully reset Windows 7 password and you can freely access to Windows 7 system. And then you can reset the forgotten Windows 7 password from: “Start->Control Panel->User Accounts”.
2. Make best use of the third-party Windows 7 password resetting tool.
Actually only a few computers users didn’t notice of the importance of password protecting the Windows built-in administrator, so if you failed to reset Windows 7 password, then to unlock your locked machine goes to use a professional Windows password resetting to like Windows Password Key Professional.
Here’s how Windows Password Key Professional works:
Step1: Download Windows Password Key Professional and install it to an accessible computer properly.
Step2: Prepare for a blank CD/DVD/USB.
Step3: Insert the CD/DVD/USB to another computer, and then click “Burn” button to start burning an ISO image file to the CD/DVD/USB.
Step4: After finishing the burning, remove the CD or DVD from the computer and then insert this CD or DVD to the locked computer.
Step5: Set the locked computer to boot from CD/DVD/USB in BIOS.
Step6: Reset Windows 7 password with burned CD/DVD/USB. A few seconds later, you will successfully reset Win 7 password and then get access to your computer again.
