CSS Form Builder error
Just installed CSS FB and it came up with the error as shown in the image when I was completing the build.
I did delete the wincache file after installing the extension.
Any ideas please?
John
Any ideas please?
John
After creating a CSS Form I cannot seem to save it and am getting another error, please see attached image.
The first error means you need to clear your activations.
Log into the download center to click the Reset Activation link.
the second error message usually happens if you start the CSAS Form Builder wizard from the Preset manager.
Make sure you are using the WebAssist -> Forms -> Create New Form access point to start the form builder wizard.
if you continue to have more problems, please provide additional details such as version of form builder that is installed, versions of other extensions that are installed, and your OS.
Thanks Jason
I cleared the activations and tried to build a css form.
I received the error message as the attached image.
After clicking a few times I next received another error message as attached image
what version of form builder do you have installed, these are errors that occurred in 2.0.0, and are fixed in 2.0.1
please uninstall the previous version of form builder from the extension manager and install the latest version from the download center.
Thanks Jason
That solved the problem.
I wonder is there a short list somewhere that shows the latest extensions?
I also remember you saying all future extensions would be for cs4 and upwards. Is there a list of extensions in that category?
Have a great weekend.
Regards
John
the download center shows the latest version number for each extension.
the following page lists all extension that are currently available:
dreamweaver-extensions/
each extensions product details page will list the dreamweaver versions it is compatible with.
