Buttons shows in FireFox but not in IE 9
Thread begun 4/15/2012 12:32 pm by janet259027 | Last modified 4/18/2012 7:09 am by janet259027 | 4276 views | 4 replies |
janet259027
Now I can see the buttons in both FireFox and IE9, but the rollover is not working in IE9 and the rounded corners show in FireFox, but they are square with a small white inside border in IE9. Is this normal for IE9?
the rounded corners use CSS 3 elements which are not supported in all browsers but should work in IE 9, please send a link so i can investigate the problem.
janet259027
Here is the link...
Thanks Jason. Here is the link: series-101.php
The buttons show in IE9 as square and they don't change when you hover over them. They work fine in FireFox.
your button layout is using a gradient color.
In IE, all versions, the gradient filter can only be applied to a square box.
IE 9 has support for using CSS Based Rounded corners, but since you are also using a gradient background color, the gradient box is over riding the rounded corners.
rounded corners in IE 9 will only work with a set flat background, it will not work with a gradient background.
janet259027
Thanks for the info. I didn't know that :-)
