Using and naming of WA email templates
Thread began 4/12/2012 5:25 am by evansg7124312885 | Last modified 4/12/2012 10:38 am by Jason Byrnes | 483 views | 1 replies |
evansg7124312885
The GSG recommends using a template and then later modifying it. I am using that and it appears to work fine, emails are sent quickly and appear as expected.
My question is about the naming of these files. The site I am building will create an email from several different pages for different processes. When I enable the create file option, can I specify a name for it without altering the original template? I would like to name the file in a way that I can relate to it's origin. If I can not do this, when I create future files using the same design, will it over write an existing file or will it modify the new file's name (template, template1, etc).
Thanks,
a file for the template will be created in the webassist/email/templates folder.
a unique file will be created for each email using the naming convention of "<template type><int>"
so if you select the Block template type in 2 different emails, you will have 2 different templates files:
block.php
block1.php
