Conflict between WA_CMS/WA_CMS.php and powercms/WA_CMC/WA_CMS.php
Thread begun 4/11/2012 7:04 pm by anwosu310937 | Last modified 4/19/2012 11:57 pm by anwosu310937 | 2773 views | 4 replies |
anwosu310937
I am having problems using PowerCMS 2 on the live server.
1. After installing PowerCMS 2 the username and password don't work after closing the browser and starting it again.
2. I seem to have a conflict between the WA_CMS.php file in my DOCUMENTROOT and in the powercms folder. I did not delete the installation folder as instructed after the installation because I did not know what it was.
I appreciate any explanation
anwosu310937
Conflict between WA_CMS/WA_CMS.php and powercms/WA_CMS/WA_CMS.php
Thanks Jason for your response. The username/password partwas resolved when I saw an earlier posting by you. It appears I should not be copying wa_settings from my local testing server to the live server. importing only the contents tables solved the problem.
I am still stuck with the conflict issue.
This is what I get:
Fatal error: Cannot redeclare wa_getcmscontent() (previously declared in /homepages/29/d407531812/htdocs/WA_CMS/WA_CMS.php:10) in /homepages/29/d407531812/htdocs/powercms/WA_CMS/WA_CMS.php on line 66
your page has a require once line referencing the file from this location:
WA_CMS/WA_CMS.php
and another referencing the file from this location:
delete one of those require once lines.
anwosu310937
Thanks a lot. Problem solved.
Gus
