Time on email not local
Hello,
The email message recieved after the form is sent is not the local time I sent it. It is off by 6 hours.
How do I fix it. I'm on Daylight central US time .
Thanks,
Larry
Hello,
Thanks,
Larry
the timezone is set by the host in the php.ini file, you can add the following code at line 1 to override the host setting and change it to central time:
date_default_timezone_set('US/Central');
