Need help storing variable in table
Thread began 4/09/2012 2:54 pm by Dennis | Last modified 4/10/2012 7:37 pm by Dennis | 1455 views | 8 replies |
Dennis
With my WADA Insert, Update & WASA Profile pages I would like to store a field in the database based on a field in the form.
From the two digit State entered on the form I would like a Region field in the database table updated. Might I be able to select this Region from a short list of arrays such as…
$eastern
= array('CT''DE''DC''ME''MD''MA''NH''NJ''NY''PA''RI''VT''QC''NL''PE''NS''NB');
$southern = array('AL''FL''GA''LA''MS''NC''SC''VA''WV');
$central = array('IL''IN''KY''MI''OH''TN''WI''ON');
$great_plains = array('AR''CO''IA''KS''MN''MO''MT''NE''NM''ND''OK''SD''TX''WY''MB''SK''NT');
$western = array('AK''AZ''CA''HI''ID''NV''OR''UT''WA''AB''BC''YT');
if (
in_array($row_WAATKmemberaccounts['State'],$eastern))
$region 'Eastern';
elseif (
in_array($row_WAATKmemberaccounts['State'],$southern))
$region 'Southern';
elseif (
in_array($row_WAATKmemberaccounts['State'],$central))
$region 'Central';
elseif (
in_array($row_WAATKmemberaccounts['State'],$great_plains))
$region 'Great Plains';
elseif (
in_array($row_WAATKmemberaccounts['State'],$western))
$region 'Western';
else
$region 'International';
Does the above code look correct/usable?
But now I don&#8217;t know how to get my variable $region stored into the table field labeled Region.
Your help would be appreciated
Note: this question is similiar to my post post #118796 however I dodn't have the skills to adapt the suggested tutorial.
Thanks,
Dennis
there are a few problems with your code:
1) the format of your if, elseif statement is not correct.
an if statement should be formatted as:
if(condition) {
do something
} elseif(condition) {
do something else
} else {
do another something
your if statement is missing the "{" and "}"
2) instead of setting an application variable:
$region
use a session variable:
$_SESSION['region'] = 'Eastern';
3) in your if statement, don't use the state recordset column:
in_array($row_WAATKmemberaccounts['State']),$eastern)
instead, use the state form element, assuming the form element is named State:
in_array($_POST['State']),$eastern)
4) go to the bindings panel, click the plus button and select Session Variable, name the session binding "region". In the insert behavior, bind the region column to the region session variable.
Dennis
Thank You Jason,
However I am having problems that appear to be due to using the form element name.
In fact if I add (<?php echo $_POST["State"]; ?>) the page displays ()
Here is the code in the form to enter the state...
<tr><th>State:</th>
<td><input type="text" class="WAATKTextField" name="State" id="State" value="<?php echo(str_replace('"', '&quot;', $row_WAATKmemberaccounts['State'])); ?>" size="32" /></td></tr>
I have tried this with both the profile page from WASA and the update page from WADA. And with other form element names, placing the echo statement within and outside the form tags. And with single or double quotes around the form element name in the echo statement.
Dennis
please provide more details, are you getting an error message? if so what is the error.
Dennis
In my localhost (WampServer) environment i get "Notice: Undefined index: State in ..." the line number matches the first line of my if statement
$eastern
if (
in_array($_POST['State'],$eastern)) {
$_SESSION['membersRegion'] = 'Eastern';
} else {
$_SESSION['membersRegion'] = 'International';
No error on the remote server but the if statement fails, the reponse is always "International" when I insert any of the state codes in the $eastern array in the "State" field of the form.
Dennis
please send a copy of the page so I can see the code in context.
Dennis
Attached.
Thanks,
Dennis
member_Profile.zip
you cant set a varibale based on the post untill the form is sent
use this code:
$eastern
if ((isset(
$_POST["MM_update"])) && ($_POST["MM_update"] == "WAATKUpdateForm")) {
if (
$_POST['Region'] = 'Eastern';
} else {
$_POST['Region'] = 'International';
to set the region form element, and put it at line 1 of your page.
Dennis
Thank You
Jason,
Appears to be working.
Thank you very much for your help. I have been trying to get that to work for months.
Dennis
