Add to cart button - pages go blank
Thread began 4/04/2012 3:23 pm by rgolab68503 | Last modified 4/10/2012 9:52 am by Jason Byrnes | 2937 views | 11 replies |
rgolab68503
Hoping someone can help me here. I am going through the steps of ecart. I am the point where they ask to enter athe "add to cart" buttons. I add them and go to test my page and I get a blank white page. If I remove the eCart Object and eCart Add From Recordset and reload the page everything comes back fine.
I have attached my results page and here is a link to the page itself.
results_test.php?S_ItemCatID=3&Search.x=51&Search.y=5&Search=Search
Here is the starting search.php page if it helps:
search.php
I am at my wits end, I am sure it is a simple error in the script but I can't find it. Any ideas please? :(
eCart is the newest version eCart5
results.zip
The code for the include files is using the virtual function:
//WA eCart Include
virtual("/WA_eCart/ToyoPOPcart_PHP.php");
in the site definition, there is an option called "Create Links Relative To" if you select the "Site" option, dreamweaver uses the virtual function for includes, using the virtual function is only supported in a small number of php servers though. you should select the Document option so that dreamweaver will the require_once function instead.
rgolab68503
error code
Hi Jason, thanks for that, I have cleaned up the connections and tested and it worked fine. i then re-installed the buttons for cart but now I get this error message ...
Notice: Undefined variable: ToyoPOPcart in /var/www/html/toyo_support_site/support/POP/results.php on line 9
Fatal error: Call to a member function GetContent() on a non-object in /var/www/html/toyo_support_site/support/POP/results.php on line 9
Still a white screen.
I'll search through the forums to see if I can see anything on this but if you have a quick answer it would be appreciated. Cheers!
Ron
probably code order. it sounds like the include line for the cart object is after the get content line to instantiate it, send a copy of the page an i can tell for sure.
rgolab68503
error message
Here is the file attachment. You can also go to the initial search page at :
search.php ... and choose any item from the drop down which brings you to this results page.
Thanks for your help by the way.
results.zip
move the following code from line 54 - 57:
//WA eCart Include
require_once("../../WA_eCart/ToyoPOPcart_PHP.php");
to line 8
rgolab68503
error message
Hi Jason,
That didn't really do it. Because I had the initial error I then removed the add to cart buttons. There were also other includes which started with "virtual". This may have contributed to things being messed up. I am starting from the beginning again recreating the checkout page and cart pages etc.
I'll let you know how it goes.
rgolab68503
Error message
Hi Jason,
I have recreated the cart. I had a bit of an issue where I changed the colour scheme and named it Pacifica_toyo_final, but for some reason it renamed it Pacificatoyofinal without any underscores. I corrected this adn am able to see the pages and teh buttons correctly. However when I try to update the cart, change or checkout I get this error message.
Notice: Undefined index: eCartCheckoutForm_street2 in /var/www/html/toyo_support_site/support/POP/cart.php on line 279
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '03:28:14,'')' at line 1
There seems to be a a conflict whith what is I sending to the checkout page but I haven't been able to find where I can remedie this.
send a copy of the cart.php page so i can see the code please.
rgolab68503
error message
Hi Jason,
I have attached the checkout files if that helps.
I have gone through a bunch here. Trying one thing then another. I am at a point where the cart seems to add the item but the cart displays a "the cart is empty" message. If I try to hit the update or continue shopping or any of the buttons, I get this error.
Notice: Undefined variable: ToyoPOPcart in /var/www/html/toyo_support_site/support/POP/checkout.php on line 9
Fatal error: Call to a member function GetContent() on a non-object in /var/www/html/toyo_support_site/support/POP/checkout.php on line 9
In addition to this, I get a java script error if I try and open any of the buttons in the server behaviours (see attachment Error_java.jpg).
I keep thinking I must have done something wrong in the beginning. I am thinking to start once again and this time not changing the colour scheme so I don't get that error. What do you think? Start over?
Thanks for you help ... Ron
POP.zip
