Layout issues in Data assist
I have two columns and data assist is ignoring the template and the information is not stored in the correct place
please provide more details.
is the template saved as a dynamic php template? Dynamic templates need to be saved using the extension:
.dwt.php
in the DataAssist wizard, on the first page, you can select from a list of dynamic templates for your site, you will also need to select which editable region data assist ads the forms to.
Hi Jason
Yes i have saved it as an dynamic template and it has two selectable editable regions in the templates
a copy of the template would help.
also some details on what editable region you are selecting when running the wizard. what is the outcome of the pages created versus what you expect the outcome to be, perhaps a screen shot would help.
the limited details you are providing is making it difficult to offer guidance.
Hi Jason
The test server of the template is on my computer i will use screen shot for you.
from your screen shot it looks like the data assist form is in the content editable region, i don't see the problem.
Well theres two regions and main content one and one for the menu bar and thats being pushed aside
the menu bar is showing at the top of the page, it does not look like it is being pushed aside to me.
The menu bar section is the section for the categories for the website shop and this is a vertical column the main section is taking over this and dropping it below menu section
