display error box or success
Thread began 4/02/2012 1:54 pm by randyw2394710 | Last modified 4/04/2012 7:09 am by Jason Byrnes | 3419 views | 5 replies |
randyw2394710
I would like to create an error box or thank you box on the same page as the form is on
i have some of it done it doesnt add in duplicates
basically the form will submit check if its new user email or not if its new user email it inserts the user and displays the thank you green box when the page is reloaded from another page i need the box to go away
if the user email allready exists it will display the red failor box and no insert
also when page is resubmitted would like to clear all form fields so the boxes only appear once on submit
index.zip
you already have the validation i nplace to check if the email exists, to show the error box, create it on your page, then select it and use the validation Show If Behaivor arournd it so it will only show if the Numeric validation fails.
for the success box, the insert creates a session variables named:
pcms2_Newsletter_UserID
use an if statement to check if that session is set to show the success message:
<?php if(isset($_SESSION['pcms2_Newsletter_UserID']) && $_SESSION['pcms2_Newsletter_UserID'] != "") { ?>
Success message here
<?php ?>
and add the following code at the bottom of the page to reset the session:
<?php if(isset($_SESSION['pcms2_Newsletter_UserID'])) unset($_SESSION['pcms2_Newsletter_UserID']); ?>
randyw2394710
<?php ?>
i tride what you said. the erorr box appears on page load even when there is no info in data base when you add your information, the error box disappesars and the thank box is shown.
also in the validation show if validation page, is there a way to make it self because this form will be on all the pages
here is a link to show what im talking about thanks i believe im finnally close
index.php
index.zip
randyw2394710
have you looked into new reply
if you leave the validation redirect empty, it will automatically redirect to self. to fix the problem with the error showing on page load, add the following code at the bottom of the page:
<?php if(isset($_SESSION['WAVT_usersRegistration_Errors'])) unset($_SESSION['WAVT_usersRegistration_Errors']); ?>
