Problem with CSS Form Builder
Thread began 4/02/2012 9:06 am by davidirvan2000437653 | Last modified 4/03/2012 8:37 am by Jason Byrnes | 981 views | 3 replies |
After creating a form step by step using the tutorial for CSS form builder this is the error message I received. What am I doing wrong?
Warning: require_once(/home/prayer/www/www/webassist/html_editor/fckeditor.php) [function.require-once]: failed to open stream: No such file or directory in /home/prayer/www/www/webassist/html_editor/waricheditorphp.php on line 1
Fatal error: require_once() [function.require]: Failed opening required '/home/prayer/www/www/webassist/html_editor/fckeditor.php' (include_path='.:/usr/local/php53/lib/php') in /home/prayer/www/www/webassist/html_editor/waricheditorphp.php on line 1
sounds like the webassist/html_editor/ folder may not have been completely uploaded, make sure all of the files in the webassist/html_editor/ folder are uploaded to the server.
That was it, I appreciate the feedback. For some reason when I was uploading the entire site in dreamweaver it was not uploading that folder, so I went and specifically "Put" the "webassist" folder and everything is working. I really appreciate that.
you're welcome.
