Bug regarding plugins and page encoding tags?
Thread begun 4/02/2012 9:02 am by Steve | Last modified 4/27/2012 6:25 am by Jason Byrnes | 2342 views | 3 replies |
Steve
Hello,
I just noticed that using the Framework , a basic Dreamweaver template and two Plugins (static) will yield multiple page encoding tags in the final browser rendered page. In other words the encoding tag from the head of each plugin will also render in the final pages code.
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
Is this a know issue? I can strip the page encoding from each plugin linked page but if there is another recommended method please advise.
yes, this is a known issue and has been logged in our bugbase, the workaround is to remove the meta tags from the plugin pages and only include them in the template page.
info4753
Got the same problem here.
Charset of the main page and included page is <meta charset="utf8" />. After applying a static plugin, I get an additional <meta charset="ISO-8859-1"> on the main page that causes a lot of troubles.
To prevent the problem from happening, remove the meta tags from the plugin pages. only include the meta tags on the main page that uses the plugins.
