All kinds of errors and formatting problems with Site Sculptor
I went through the normal operations of creating a layout in CSS sculptor, making it a DW template, creating a new preset in the preset manager for site sculptor designs, made my navigation menus etc. Then I went to create the site in site sculptor and started getting all these errors and problems (see attached). I also got a syntax error on my index.html line 157 - "po.src = sitesculptor_assets/home/js/plusone.js';" . This is also the same type of coding that gives me an error in the site sculptor wizard. They all start with po.src = The first two images show the dwt I made and then the layout site sculptor made. As you can see it is forcing the content area all the way to the right and making it like 30 px wide. I've never had these problems before and I did delete the .dat file and reinstall extensions. The 4th image in happens like 3 times in a row and just changes the line that the error is on. When I click on any text in the index.html page, it selects everything on the page.
On a side note, if I plan on implementing data assist, ecart and security assist, should I have used site sculptor to make php pages, or will the html pages be ok to work with/around?
I was hoping restarting everything would work so deleted the site, remade everything and i still get the errors. When I click on any of the other presets it previews and works fine, it is when I choose the preset for the Site Design that the error for the unterminated string constant shows up. When i create a new page from template, everything is fine. So it seems to be a problem when I put the design into site sculptor.
I read a lot into the database topics and how to setup a user system, make an order history page etc etc and was excited to get rolling with this personal site of mine. Please help me get this resolved ASAP, im anxious! Thanks
These lines are giving me errors (even after I deleted the code from the dwt it says I have error on line 147, and there is no line 147):
if($('.textItem').length > 1)
and then the } before the "else"
$(document).ready(function()
setupRotator();
function setupRotator()
$('.textItem:first').addClass('current').fadeIn(1000);
setInterval('textRotate()', 10000);
function textRotate()
var current = $('#quotes > .current');
if(current.next().length == 0)
current.removeClass('current').fadeOut(1000);
else
current.next().addClass('current').fadeIn(1000);
</script>
