Upgrading from 1.0 to 2.0 ..
Just upgrades to SecurityAssist 2.0
Do I need to remove SecurityAssist 1.0 sb?
How to I update existing site using 1.0??
What happens to 1.0 site files?
Does 2.0 overwrite existing files ?
jrt
jrt
upgrading the extension in Dreamweaver will have no effect on the files in your site using Security Assist 1.
If you wish to upgrade a site that was created using security assist 1, you will need to go to the server behaviors panel, double click each security assist behavior on each page and click OK to have the behavior code regenerated using the security Assist 2 code. This really isn't necessary to do though if the site is already working fine.
