Cnanging Server ?
Hello:
I am about to change 2 sites to a new server. Both sites incorporate Power Gallery. What would be the procedure to insure that it works on the new servers. Any help would be greatly appreciated.
Thanks. Rich
Hello:
Thanks. Rich
You will need to export the Gallery database using PHPMyAdmin from the old server, then import it on the new server.
then in the power gallery files, edit the Connections/PowerGalleryConnection.php file to use the correct MySQL connection details to connect to the new database server.
