CSS Form Builder form looks different on a PC
Thread began 3/26/2012 7:56 pm by chris373619 | Last modified 3/27/2012 4:23 pm by Jason Byrnes | 648 views | 3 replies |
chris373619
I posted this earlier but don't see the link online anymore.
I have a form build the the CSS Form Builder.
It looks different on the PC than it does on the mac.
How do I fix this??
contact_RV_SuperStorage.php
Thanks,
Chris
need to make 2 code changes:
change:
<form action="contact_RV_SuperStorage.php" method="post" name="contact_RVStorage_currentDesign" class="RVStorage_currentDesign" id="contact_RVStorage_currentDesign" onsubmit="WAValidateRQ(document.contact_RVStorage_currentDesign.Contact_Us_group_What_Will_You_Be_Storing,'- Entry is required',document.contact_RVStorage_currentDesign.Contact_Us_group_What_Will_You_Be_Storing,0,true,'select');WAValidateCD(document.getElementById('contact_RVStorage_currentDesign').Contact_Us_group_What_Will_You_Be_Storing,document.getElementById('contact_RVStorage_currentDesign').Contact_Us_group_Other,false);WAValidateRQ(document.contact_RVStorage_currentDesign.Contact_Us_group_How_did_you_hear_about_us,'- Entry is required',document.contact_RVStorage_currentDesign.Contact_Us_group_How_did_you_hear_about_us,0,true,'select');WAValidateCD(document.getElementById('contact_RVStorage_currentDesign').Contact_Us_group_How_did_you_hear_about_us,document.getElementById('contact_RVStorage_currentDesign').Contact_Us_group_Other_2,false);WAValidateRQ(document.contact_RVStorage_currentDesign.Contact_Us_group_Other,'- Entry is required',document.contact_RVStorage_currentDesign.Contact_Us_group_Other,0,false,'text');WAValidateRQ(document.contact_RVStorage_currentDesign.Contact_Us_group_Other_2,'- Entry is required',document.contact_RVStorage_currentDesign.Contact_Us_group_Other_2,0,false,'text');WAAlertErrors('The following errors were found','Correct invalid entries to continue',true,document.getElementById('false'),false);return document.MM_returnValue">
WebAssist CSS Form Builder - Form v1
CC: RV superstorageContact
CP: contact
TC: RV Storage
TP: current Design
<ul class="RVStorage_currentDesign">
CP: contact
TC: RV Storage
TP: current Design
and change:
</ul>
</form>
</form>
</ul>
chris373619
I think that worked except now it has a bullet before the form in the design. How do I get ride of that?
add the following style:
ul.RVStorage_currentDesign {
list-style: none;
