Design Edit Theme page not coming up
I am in testing mode at this time, but I had everything working until I started playing around with trying to edit the look and feel of my store via the template php files and css. I replaced the files after changing the look a bit. Also once of the themes is missing altogether now (shows blank on the them called Crazy, which is one I wanted to use). When I go to the Design page and select Edit Theme on any of the themes, nothing comes up. Do I have to reinstall everything or can this be easily fixed. On internet explorer I get the error:
The website cannot display the page
HTTP 500
Most likely causes:
•The website is under maintenance.
•The website has a programming error.
What you can try:
Refresh the page.
Go back to the previous page.
More information
This error (HTTP 500 Internal Server Error) means that the website you are visiting had a server problem which prevented the webpage from displaying.
For more information about HTTP errors, see Help.
