Re-enter dynamic framework plugin
When i add a dynamic framework to my page everything works fine. I also see the dynamic plugin in my server behavior tab in DW. When i click that behavior i can re-enter the dynamic framework plugin but if i then add some additional criteria in the fields and when finish click ok, it does not add anything to the code. When i re-enter the plugin again all is back to how it was.
Should it not be possible to re-enter this plugin to add conditions to it this way or do i do something wrong. When i add all conditions the first time i use the plugin then all is ok, i just cannot add anything once the plugin is applied to the page by re-entering it.
Is it a bug?
Dave
