Error when adding new menu
Thread begun 3/23/2012 4:06 pm by krforman437131 | Last modified 3/26/2012 8:12 am by Jason Byrnes | 2226 views | 1 replies |
krforman437131
I get this error when i try to add a new menu item,
you have selected in the Content Column. This page will contain the same content areas as the template.
Warning: require_once(../../Connections/PowerCMSConnection.php) [function.require-once]: failed to open stream: No such file or directory in
D:\home\scs-scheduler.com\wwwroot\powerstore\admin\common\addpage.php on line 1
Fatal error: require_once() [function.require]: Failed opening required
'../../Connections/PowerCMSConnection.php' (include_path='.;D:\PHP\5.2\pear') in D:\home\scs-scheduler.com\wwwroot\powerstore\admin\common\addpage.php on line 1
Content Name: Cancel
Choose the content area you wish to edit below
Custom Pages (2 editable regions) | Page Optimization
Could someone please help me.
Thank You
see this thread for a fix:
showthread.php?t=25405
