PowerCMS Editor Stylesheet
Thread began 3/21/2012 5:52 am by alan56669 | Last modified 3/28/2012 11:06 am by Jason Byrnes | 1423 views | 7 replies |
alan56669
I am using PowerCMS 2.1 and would like to use some of the styles used in my website (i.e. css formatted tables) in the editor used by the site administrators.
I have populated the dropdown style list in the editor with a number of styles used in the site to assist the administrators in keeping aligned with the styles used in the main site but i cannot fathom out how to change the editorarea to use table styles.
When the user clicks on the table icon in the editor toolbar and chooses the number of rows and columns i want a specific style to be applied, i.e. like what will appear on the main site when the page is loaded.
Any help here would be gratefully received.
Regards
Alan Edwards
in the table properties dialog box, you need to go to the advanced tab and enter the id to apply an ID based style, or the table classes to apply class based styles.
alan56669
Hi Jason, thanks for you swift reply but i'm still confused.
For the editor area to display the table style does the style need to be added somewhere first, if so what css style sheet or JS file do i need to include the styles in before i can use them in the table properties dialog box?
Thanks in advance.
Regards
Alan
yes, the style will need to be fined in the CSS File that you have attached to the page that displays the editor area
alan56669
Hi Jason,
When i change the CSS stylesheet that is attached to the PowerCMS contents_update.php page it changes the whole page including the PowerCMS admin look and feel.
The area is does not change however is the editor area itself.
Am i missing something, or have i lost the plot completly?
Cheers
Alan
OK, try doing it this way:
Edit the HTML Editor instance. Click the Pencil icon next to the preset to edit the preset.
In the styleing tab, select the option to edit the styles listed in the menu.
you can select to create new styles, when you give thje new style a name, you can select that it applies to the table tag, the tr tag or the td tag.
in the bottom section, you can define the style attributes like border or font size / color.
after adding the table in the editor, select it, then from the style menu select the stye that was defined for the table.
alan56669
Hi Jason,
As i am using POWERCMS and the page in question is the contents_update.php that is part of the POWERCMS suite there is no visible editor in the page for me to click and edit.
The following code appears in the source of the page though....
// The initial value to be displayed in the editor.
$CKEditor_initialValue = "".($totalRows_HistoryUpdate > 0)?((isset($_POST['ContentValue']) && $row_HistoryUpdate['HistoryValue'] != $_POST['ContentValue'])?$row_WADAContents['ContentValue']:$row_HistoryUpdate['HistoryValue']):$row_WADAContents['ContentValue'] ."";
$CKEditor = new CKEditor();
$CKEditor->basePath = "../webassist/ckeditor/";
$CKEditor_config = array();
$CKEditor_config["wa_preset_name"] = "Blank (custom)";
$CKEditor_config["wa_preset_file"] = "(custom)";
$CKEditor_config["width"] = "98%";
$CKEditor_config["height"] = "300px";
$CKEditor_config["skin"] = "kama";
$CKEditor_config["docType"] = "<!DOCTYPE HTML PUBLIC \"-//W3C//DTD HTML 4.01 Transitional//EN\" \"http://www.w3.org/TR/html4/loose.dtd\">";
$CKEditor_config["contentsLanguage"] = "";
$CKEditor_config["dialog_startupFocusTab"] = false;
$CKEditor_config["fullPage"] = false;
$CKEditor_config["tabSpaces"] = 4;
$CKEditor_config["filebrowserBrowseUrl"] = "../webassist/kfm/index.php?uicolor=".urlencode(isset($CKEditor_config["uiColor"])?str_replace("#","#",$CKEditor_config["uiColor"]):"#eee")."&theme=webassist_v2";
$CKEditor_config["toolbar"] = array(
array( 'Source','-','Preview'),
array( 'Cut','Copy','Paste','PasteText','PasteFromWord','-','SpellChecker'),
array( 'Undo','Redo','-','Find','Replace','-','SelectAll','RemoveFormat'),
array( 'Image','Flash','Table','HorizontalRule','Smiley', 'SpecialChar','PageBreak'),
array( 'Bold','Italic','Underline','Strike','-','Subscript','Superscript'),
array( 'NumberedList','BulletedList','-','Outdent','Indent','Blockquote','CreateDiv'),
array( 'JustifyLeft','JustifyCenter','JustifyRight','JustifyBlock'),
array( 'Link','Unlink','Anchor'),
array( 'Styles','Format','Font','FontSize'),
array( 'TextColor','BGColor'),
array( 'Maximize','ShowBlocks'));
$CKEditor_config["scayt_autoStartup"] = true;
$CKEditor_config["contentsLangDirection"] = "ltr";
$CKEditor_config["entities"] = false;
$CKEditor_config["pasteFromWordRemoveFontStyles"] = false;
$CKEditor_config["pasteFromWordRemoveStyles"] = false;
$CKEditor_config["stylesCombo_stylesSet"] = "my_styles:style_lists/stylelist1.js";
$CKEditor->editor("ContentValue", $CKEditor_initialValue, $CKEditor_config);
Thanks for your continued support i appreciate it.
Regards
Alan Edwards
I see, sorry i missed the part that was CMS Builder.
you will need to edit the webassist/ckeditor/style_lists/stylelist1.js to add the table style.
for example, the last style defined in that file is:
{ name: "contentpage-clicked",  element: "span",  ordered_list: [ "a:0" ],  attributes: { "class" : "contentpage-clicked" } }
you would need to add your style for the table tag after that like this:
{ name: "contentpage-clicked",  element: "span",  ordered_list: [ "a:0" ],  attributes: { "class" : "contentpage-clicked" } },
{ name: "tableStyle", element: "table", ordered_list: [ "s:0" ], styles: { "border" : "1px solid black" } }
