Errors when trying to edit theme, need help!
Thread began 3/20/2012 12:58 pm by admin140217 | Last modified 3/20/2012 1:20 pm by Jason Byrnes | 837 views | 2 replies |
admin140217
I am getting loads of errors when trying to edit the current theme I am using on PS 4.5. Below are the errors. This just started happening as I have only been updating the products recently.
Warning: fopen(../../themes/temp_editing/css/configurable.css) [function.fopen]: failed to open stream: No such file or directory in D:\Hosting\2943569\html\store\webassist\plugins\styler\styler.php on line 105
Warning: filesize() [function.filesize]: stat failed for ../../themes/temp_editing/css/configurable.css in D:\Hosting\2943569\html\store\webassist\plugins\styler\styler.php on line 106
Warning: fread(): supplied argument is not a valid stream resource in D:\Hosting\2943569\html\store\webassist\plugins\styler\styler.php on line 106
Warning: fclose(): supplied argument is not a valid stream resource in D:\Hosting\2943569\html\store\webassist\plugins\styler\styler.php on line 107
Warning: simplexml_load_file() [function.simplexml-load-file]: I/O warning : failed to load external entity "../../themes/temp_editing/theme_settings.xml" in D:\Hosting\2943569\html\store\webassist\plugins\styler\styler.php on line 110
Fatal error: Call to a member function asXML() on a non-object in D:\Hosting\2943569\html\store\webassist\plugins\styler\styler.php on line 123
I really don't know what the errors mean except to say it's something with the Styler.php page, I'm a novice at PHP, I can set up but triubleshooting is not my area of expertise.
Help would be great!
chuckdonaldson421003
Same issue
I am experiencing the same issue. Please help!
