UE Not Sending
Thread began 3/19/2012 10:09 am by steve287725 | Last modified 3/21/2012 2:45 pm by Jason Byrnes | 1043 views | 5 replies |
steve287725
UE Not Sending
Hello there
I have just attached UE4 to a pretty standard contact form and I have used a bit of jQuery validation - here for reference;
jQuery-Validation-Engine
The mail just does not send - the form seems to submit OK but the mail never arrives, either to an address in the same domain or another address.
I have added the code in this thread;
showthread.php?t=25492
This just returns this -
<pre>array(0){} </pre>
I have attached the page - do you have any pointers please I am just a bit stuck here . . .
Many thanks
Steve
enquiries.zip
does it redirect to the thank you page?
if it directs to the thank you page, then the email is being sent to the SMTP Server, it is the SMTP server that is refusing to relay the message.
if it does not redirect to the thank page, then there may be a php error occurring.
add the following cade to line 1 of the page to turn error reporting on:
error_reporting
(E_ALL);
steve287725
Redirecting fine
I have added the code and the page redirects to the thank you page fine as it did before - no apparent errors, but still no email.
Anything else I can but but interrogate the server logs?
the code was only needed if the page did not redirect to the thank you page.
since it is directing to the thank you page, it is trying to send the email to the SMTP Server, but the smtp server is refusing to relay the message.
who is you host?
What did you enter for the SMTP server in the UE settings
Send a link where i can see the form please.
steve287725
Solved
Jason
Just to let you know that this has been sorted - fault of the hosting provider.
Thanks for your input
ok, glad to hear it is working.
