Javascript error
I have had problems with the extension since I first installed it in CS5.5. I wanted to use it in templates, but it would only work correctly if I manually chose which URL it was supposed to point to.
I decided to try and fix my preferences to see if that would allow me to use it on templates. I am receiving the attached error message when trying to change webasist preferences.
I have deleted the dat file - error still appears. I then removed the extension and deleted the dat file. When I re-installed the extension, the error still appeared.
Please help! I really need this to work in my templates. That is the only reason I purchased it.
