Simple template breaks WADA Wizard
Thread began 3/16/2012 9:34 am by neo314 | Last modified 3/16/2012 11:55 am by Jason Byrnes | 1136 views | 3 replies |
neo314
This simple template break the WADA Wizard and produces javascript errors which seem to be related to the rendering engine. The result is pages created using the wrong table (as in the last one I did), wrong template applied, and blank files created in the editor (as in untitled-6.php, untitled-7.php, etc.)
<head>
<!-- TemplateBeginEditable name="doctitle" -->
<title></title>
<!-- TemplateEndEditable -->
<link href="/admin/css/adminForms.css" rel="stylesheet" type="text/css" />
<script type="text/javascript" src="/inc/jQuery/jquery.min.js"></script>
<script type="text/javascript" src="/inc/jQuery/jquery.validate.min.js"></script>
<script type="text/javascript" src="/inc/jQuery/jquery.validate.additional-methods.min.js"></script>
$(document).ready(function() {
$("#closeBtn").click(function() {
parent.$.colorbox.close();
</script>
<!-- TemplateBeginEditable name="head" -->
</head>
<body>
<!-- TemplateBeginEditable name="body" -->body<!-- TemplateEndEditable -->
</body>
</html>
can you send a copy of the JQuery script files:
so i can recreate the template and try to reproduce the problem.
neo314
Sure. They are attached along with the template file.
template_issue.zip
i was able to use this template without an issue.
A workaround is to generate the pages without using the template, then apply the template to the pages after they are created, Modify -> Templates -> Apply Template to Page
