No Image upload
Hello
I uploaded a site with a CMS to the clients host, using the html editor but i can't upload files the screen is white see screendump. On my local server it's working perfect! I changed the chmod settings.
grts Remco
Hello
grts Remco
in the webassist/kfm/themes folder, try deleting the .htaccess file from the server
if you continue to have a problem, double check that the MySQL Server version and the PHP server version are both using 5+
I am getting the same issue, when I open the image upload feature I get a blank pop up window. I have two sites on the same server, one works fine the other doesn't work. There is no .htaccess file in the location you suggested.
SS
