I need to update all prices and dimensions with a batch process
Thread began 3/14/2012 4:32 am by mrs | Last modified 3/16/2012 5:05 am by mrs | 1289 views | 3 replies |
mrs
Hi, I have been trying to get MySQL to update the prices of all products within the ps4_products table by batch processing it with a query, but I can't get it working. I know it's possible, but I am just doing something wrong and need help.
Here's how am I trying to do it. I have the ps4_products table and I have created a table called _import_products which has all of the up-to-date info in it. I am then trying to ask MySQL to merge the info of the two tables by matching the SKU. I am expecting each record to have updated prices, weight, dimensions etc, but what I am getting is a new series of records in addition to the existing records.
Here's my query:
SELECT ProductSku, COUNT(ProductSku) _import_products FROM _import_products
GROUP BY ProductSku;
UPDATE ps4_products
INNER JOIN _import_products ON (_import_products.ProductSku = ps4_products.ProductSKU)
SET ps4_products.ProductPrice = _import_products.ProductPrice;
SET ps4_products.ProductWeight = _import_products.ProductWeight;
SET ps4_products.ProductWidth = _import_products.ProductWidth;
SET ps4_products.ProductHeight = _import_products.ProductHeight;
SET ps4_products.ProductLength = _import_products.ProductLength;
Here's the structure of the tables:
DROP TABLE IF EXISTS `_import_products`;
CREATE TABLE `_import_products` (
`id` int(11) unsigned NOT NULL AUTO_INCREMENT,
`ProductSKU` varchar(50) DEFAULT NULL,
`ProductPrice` float(12,2) DEFAULT NULL,
`ProductWeight` float(12,2) DEFAULT NULL,
`ProductWidth` decimal(12,4) DEFAULT NULL,
`ProductHeight` decimal(12,4) DEFAULT NULL,
`ProductLength` decimal(12,4) DEFAULT NULL,
PRIMARY KEY (`id`)
) ENGINE=MyISAM AUTO_INCREMENT=2684 DEFAULT CHARSET=latin1;
DROP TABLE IF EXISTS `ps4_products`;
CREATE TABLE `ps4_products` (
`ProductID` int(12) NOT NULL AUTO_INCREMENT COMMENT 'None',
`ProductSKU` varchar(50) DEFAULT NULL COMMENT 'Product Code/SKU',
`ProductBrand` varchar(255) DEFAULT NULL COMMENT 'Brand Name',
`ProductName` text NOT NULL COMMENT 'Product Description',
`ProductPrice` float(12,2) NOT NULL DEFAULT '0.01',
`ProductRetailPrice` float(12,2) DEFAULT NULL,
`ProductShipping` float(12,2) DEFAULT NULL,
`ProductWeight` float(12,2) DEFAULT '0.00',
`ProductCartDesc` text COMMENT 'Product Description',
`ProductShortDesc` text COMMENT 'Product Description',
`ProductLongDesc` text COMMENT 'Product Description',
`ProductThumb` varchar(100) NOT NULL DEFAULT '' COMMENT 'Product Code/SKU',
`ProductImage` varchar(100) NOT NULL DEFAULT '' COMMENT 'Product Code/SKU',
`ProductUpdateDate` timestamp NOT NULL DEFAULT CURRENT_TIMESTAMP,
`ProductStartDate` datetime DEFAULT NULL,
`ProductEndDate` datetime DEFAULT NULL,
`ProductStock` float(12,2) DEFAULT '0.00',
`ProductLive` tinyint(1) DEFAULT '1',
`ProductUnlimited` tinyint(1) DEFAULT '1',
`ProductDigital` varchar(250) DEFAULT NULL,
`ProductMaxDownloads` int(12) DEFAULT NULL,
`ProductNonTaxable` int(1) DEFAULT '0',
`ProductTitle` text,
`ProductMetaKeywords` varchar(255) DEFAULT NULL,
`ProductMetaDescription` varchar(255) DEFAULT NULL,
`ProductCategories` text COMMENT 'Category',
PRIMARY KEY (`ProductID`)
) ENGINE=MyISAM AUTO_INCREMENT=6220 DEFAULT CHARSET=utf8;
As you can see, I've added a few column to the table where sizes are kept.
I'd appreciate your help with this.
Thanks.
Mat
the update statement should look more like this:
UPDATE ps4_products
SET ps4_products.ProductPrice = _import_products.ProductPrice, ps4_products.ProductWeight = _import_products.ProductWeight, ps4_products.ProductWidth = _import_products.ProductWidth, ps4_products.ProductHeight = _import_products.ProductHeight, ps4_products.ProductLength = _import_products.ProductLength
FROM ps4_products, _import_products
WHERE _import_products.ProductSku = ps4_products.ProductSKU
see this page for an example:
update-data-in-one-table-with-data-from.html
mrs
Cheers Jason. I had this version working before I received your response, so I managed to get it working. I was in a proper mess beforehand though.
UPDATE ps4_products
LEFT JOIN _import_products ON (_import_products.ProductSku = ps4_products.ProductSKU)
SET ps4_products.ProductPrice = _import_products.ProductPrice, ps4_products.ProductWeight = _import_products.ProductWeight, ps4_products.ProductWidth = _import_products.ProductWidth, ps4_products.ProductHeight = _import_products.ProductHeight, ps4_products.ProductLength = _import_products.ProductLength;
The only thing is, if I don't have a product price available in the import table for a product that exists in the product table, the price for that existing product is overwritten to 0.00 which is dangerous to say the least. How can I stop this from happening?
Thanks.
mrs
Don't worry, I've just twigged that I hadn't got the WHERE clause in place.
If any body is interested in this capability, then here is the process to update products in your products table by batch processing from something like a CSV file.
1. Create an import table. The code for my import table is:
PRIMARY KEY (`id`)
2. Import the updated prices to the import table (I use Sequel Pro to handle imports etc).
3. Merge the two tables with this query:
UPDATE ps4_products
WHERE _import_products.ProductSku = ps4_products.ProductSKU;
Obviously, this works for my import table, and I have added fields to the products table to allow for product dimensions. It will need to be adjusted to suit your requirement.
HTH
Mat
