Email Password
Thread began 3/13/2012 12:11 pm by Cologne | Last modified 3/14/2012 11:49 am by Jason Byrnes | 922 views | 3 replies |
Cologne
Email Password
whats that for an ERROR?
I aint got a field like that in my table, why should I? Mine is called passwort.
'UserPassword' in 'field list'
I hardly try to use the EMAIL PASSWORD wizzard.
My database passwords are encrypted with HASH (md5 was not there).
I choose email to look up, the username (i have to :-( ) and the password encrypted HASH.
SA1 was so easy!
cheers,
Denis
What exactly is the error? You are question is not very clear.
can you send a copy of the page?
For MD5 encryption you need to use the Email Encrypted Password behavior under Webassist -> Security Assist -> Email Password -> Email Encrypted Password.
Cologne
Hi Jason,
the wizzard searches for fields that it creates on his own, and are not in my table.
I tried it with no encrytion.
<?php require_once('MHQ_CMS.php'); ?>
<?php require_once( "webassist/security_assist/helper_php.php" ); ?>
function WA_SecurityAssist_Email_1_SendMail($WA_Auth_Parameter){
$WA_MailObject = WA_SecurityAssist_Definition("<%=\"server_name\"%>","25","Musicheadquarter.de","","");
$WA_MailObject = WA_SecurityAssist_SendMail($WA_MailObject,"","","",$WA_Auth_Parameter["toAddress"],"",$WA_Auth_Parameter["fromAddress"],$WA_Auth_Parameter["subject"],$WA_Auth_Parameter["mailBody"]);
$WA_MailObject = null;
}// WA_SecurityAssist_Email_1_SendMail
if(isset($_POST["button"])){
//WA SecurityAssist Email object="mail"
$WA_Auth_Parameter = array(
"connection" => $MHQ_CMS,
"database" => $database_MHQ_CMS,
"tableName" => "mhq_cms_redaktion",
"filterColumn" => "email",
"filterEncryption" => "",
"columnValue" => "".((isset($_POST["email"]))?$_POST["email"]:"") ."",
"columnType" => "text",
"usernameColumn" => "email",
"usernameEncryption" => "",
"passwordColumn" => "passwort",
"passwordEncryption" => "",
"selectColumns" => array("UserName","UserPassword","email","passwort"),
"sessionVariables" => array(""),
"successRedirect" => "newPasswordSent.php",
"failRedirect" => "restricted.php",
"keepQueryString" => FALSE,
"toAddressColumn" => "email",
"toAddressEncryption" => "",
"fromAddress" => "no-reply@musicheadquarter.de",
"fromAddressDisplay" => "Admin",
"subject" => "Nüß Passwort",
"mailBody" => "User name: [UserName]\nPassword: [UserPassword]",
"emailFunction" => "WA_SecurityAssist_Email_1_SendMail"
WA_Auth_ForgotPassword($WA_Auth_Parameter);
This line
seems to be wrong, cause I didnt choose "UserName","UserPassword". my fields are "email","passwort".
Cheers,
Denis
this appears to be a bug that i have logged in our bugbase to be corrected in the next dot release.
