Populating initial value using jquery
Thread began 3/11/2012 6:12 pm by matt360561 | Last modified 3/13/2012 3:15 pm by Jason Byrnes | 971 views | 3 replies |
matt360561
Hi
I'm working on an edit screen on the webapp which uses HTML Editor. I want to populate the htmleditor with an initial value suppled via a backend script using ajax.
I've tried using $('#article').val(d.data[0].article); and this works fine for other areas and text areas but not the HTMLEditor.
Any advice, greatly appreciated.
Matt
you need to use the CKEditor setData function for this:
CKEDITOR.editor.html#setData
matt360561
Thanks Jason.
I've tried using the following for my html editor instance which is named article:
CKEDITOR.instances.article.setData( '<p>This is the editor data.</p>' );
But this doesn't seem to work. Please could you give me an example? I forgot to mention the version of HTMLEditor I have is version 2 (if that makes any difference)
Many thanks
html editor 2 make a big difference.
try using this javascript code:
window.onload = function() {
var oEditor = FCKeditorAPI.GetInstance('article') ;
oEditor.SetData( '<p>This is the editor data.</p>' );
</script>
