Help creating session variables
Where in this program do you create session variables?
on the login page, double click the Security Assist Authenticate User server behavior.
On the third step, you can select columns that will be stored in session variables.
Thanks for your response!
Ok, I did that and it worked after I figured out that it was duplicating code and I needed to delete the old code.
But when I open the Authenticate User server behavior for a second time to add more variables I find the non of the settings that I previously applied for the first variable are saved. So, I have to start all over again. Is that right?
