Manual Install
Thread began 3/07/2012 4:23 pm by jyotimarshall435194 | Last modified 3/08/2012 6:22 am by Jason Byrnes | 1145 views | 1 replies |
jyotimarshall435194
Manual Install
Is there a a way to manually install CMS to the server?
I ask this because I was having problems and deleted the folders associated with PowerCMS in hopes to re-installing it. However, now when I add a content area it simply adds it and skips the install process since it think that it is already installed.
Thanks for your help.
The install process will start if the Connections/installed.txt file is not found on the server.
Delete the powergallery.php and installed.txt files in the connections folder, and it should allow you to run the install script.
