PS4 Seems to use "PoswerCMS" commands in "addpage.php"
Thread begun 3/07/2012 6:43 am by olivier.lamarche436716 | Last modified 3/14/2012 12:37 pm by jo271221 | 9314 views | 3 replies |
In powerStore 4, when i want to create a new page ussing the admin tool, under "Content" Tab, i got the error message :
Warning: require_once(../../Connections/PowerCMSConnection.php) [function.require-once]: failed to open stream: No such file or directory in /home/ZZZZ/public_html/temp/admin/common/addpage.php on line 1
Fatal error: require_once() [function.require]: Failed opening required '../../Connections/PowerCMSConnection.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/ZZZZ/public_html/temp/admin/common/addpage.php on line 1
While my connection variable is name : PowerStoreConnection.php
I Try to replace all "PowerCMSConnection" with "PowerStoreConnection" but still, seems that some commands try to use field that dosen't exist...
(I can't post new thread on my MAC....Image verification is'nt visible)
here is an updated copy of the admin/common/addpage.php file to correct the problem
jo271221
Add page error message
I am also getting an error on adding pages - Warning: require_once(../../Connections/PowerCMSConnection.php) [function.require-once]: failed to open stream: No such file or directory in /home/content/66/9070466/html/equimedic/admin/common/addpage.php on line 1
Fatal error: require_once() [function.require]: Failed opening required '../../Connections/PowerCMSConnection.php' (include_path='.:/usr/local/php5/lib/php') in /home/content/66/9070466/html/equimedic/admin/common/addpage.php on line 1
Content Name: Cancel
jo271221
Thanks New page fixed it
