Theme not displaing
Theme is not displaying here showcasebeta.php or here index.php?gallery=1&theme=light
trying to access the file that generates the theme:
gallery.php
gives a 500 server error.
this is most likely due to a permissions problem.
Using an FTP program, log into your servers ftp , right click the galleries/ folder and select set permissions. Set the permissions to 755, make sure to have it recurse through all files and folders underneath it. I recommend using Filezilla for this:
filezilla-project.org/
also, edit the admin_gallery/common/properties.php file, change:
[php]$GLOBALS['permissions'] = array(
'dir' => 0777,
'file' => 0666
To:
'dir' => 0755,
'file' => 0755
This didn't work. I had already tried this after seeing this issue on other posts. What shall I try next?
