error while installing
After uploading files and creating a MySQL database I started powerstore/index.php and get the err shown below:
[05-Mar-2012 20:32:04] PHP Warning: require_once(../Connections/PowerStoreConnection.php) [<a href='plugins/function.require-once'>function.require-once</a>]:
failed to open stream: No such file or directory in /home/nhsc/public_html/powerstore/install/logininfo.php on line 6
[05-Mar-2012 20:32:04] PHP Fatal error: require_once() [<a href='plugins/function.require'>function.require</a>]:
Failed opening required '../Connections/PowerStoreConnection.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/nhsc/public_html/powerstore/install/logininfo.php on line 6
I am not aware that I should create the connection file, as I don't see any documentation saying that I should. (I tried anyway, but was not able to get beyond admin login, so I removed all files and started again)
I created the database file because of info in powerstore_gsg.php:
NOTE:Since most servers do not allow external applications to create new databases, you will need to create the database first through your Hosting Providers control panel. You can use an existing database, but to avoid conflicts it is advised that you start with an empty database.
The readme that came with PS 4.51 indicated that the wizard would create the database, so I'm confused.
Any help is appreciated.
Version: powerstore 4.51
