Digital Goods AND Physical Goods
Is it possible to use the install wizard to set up a store which sells both digital and physical goods or should I install twice and do a mash up?
the store can handle both digital and physical goods. when creating a product, you will be able to set whether the product is a digital product or a physical product.
The initial store setup gave a choice of one OR the other. I chose physical goods. I have a large number of physical goods setup as products. So now all I have to do is check the digital box when I setup a digital product and it will be available for download?
you will also need to set the digital goods folder in the admin section.
