Serial Number question
Thread began 2/20/2012 1:09 pm by Miguel | Last modified 2/22/2012 7:33 am by Jason Byrnes | 955 views | 2 replies |
Miguel
If i install the cms for different clients i have it always use my serial number and on the admin section under server settings it shows my serial number can i remove this so my clients can not know which is it, also checking the database it displays the serial number not even encrypted, also does the pcms have the features like site sculpter to add head tags?
mrs
I've also thought this. Is it necessary to have the serial number within the CMS and the database on the basis that this is an extension rather than a solution?
For the extension to work in the first place we have to enter the serial number when we launch it in Dreamweaver, so to have them elsewhere seems surplus to requirements.
Mat
Power CMS Builder is an extension that installs the Power CMS Solution pack to your dreamweaver site. Yes, the serial is needed for the Power CMS Install to complete, The Power CMS Solution that is installed by Power CMS Builder needs to be activated on the server.
In power CMS, you can create additional Administrator users. If logged in as an administrator, you will not have access to the settings panel, only the Supper Admin has access to the settings panel.
PowerCMS can manage header information, but you will need to create the content areas for this. for each of your content pages, create new content areas named:
meta-title
meta-keywords
meta-description
then apply the developer nots to the title, keywords and description tags on your page.
