Can't Access PM Afer Install
Just finished installing PowerMessenger and got this error immediately after. Tried refreshing and checked all permissions on FTP.
Warning: require_once(../../../../PowerMessenger Files/install_pm/webassist/framework/library.php) [function.require-once]: failed to open stream: No such file or directory in /home/content/87/8971387/html/PowerMessenger Files/webassist/themes/theme_open.php on line 6
Fatal error: require_once() [function.require]: Failed opening required '../../../../PowerMessenger Files/install_pm/webassist/framework/library.php' (include_path='.:/usr/local/php5/lib/php') in /home/content/87/8971387/html/PowerMessenger Files/webassist/themes/theme_open.php on line 6
Thanks in advance!
