The extensions are not visible in DW
Thread began 2/13/2012 9:43 am by Magic | Last modified 2/13/2012 3:11 pm by Magic | 1223 views | 4 replies |
MagicBeta Tester
Hi all,
After a lot of java script errors in Dreamweaver I decided to create new Windows profile.
Of course I needed to install all extensions again whic was also the idea behind it.
But when I start the dreamweaver I can only see the design extender, the all other extensions are not visible.
Yes I made sure the extensioans are turned on the Extension Manager.
Any idea?
Magic.
the Access points for Design Extender extensions are in the webAssist menu.
What other extensions are installed?
some may have the access points in the Insert -> WebAssist menu
MagicBeta Tester
I'm able to see all design extender( the first extension I installed) extensions but not the others like:
data assit
ecart
form builder
security assist
etc.
those other extensions will be found in the Insert -> Web Assist menu
if you are not seeing them, go to Commands -> Manage Extensions and make sure the extensions are listed as installed there, you may also need to restart Dreamweaver.
MagicBeta Tester
Problem solved.
Thanks.
