Where is MacFileCache.dat in CS5?
Thread began 2/10/2012 1:10 pm by rmlee139451 | Last modified 2/13/2012 10:57 am by Jason Byrnes | 1650 views | 4 replies |
rmlee139451
Following instructions in the Common Installation Issues after removing the older version of extensions in Design Extender, I can not locate MacFileCache.dat in DW5. The instructions cover DW3 and 4. Any thoughts?
the configuration folder path for CS5 is almost identical to the path for CS4, except you substitute "Dreamweaver CS5" where the path says "Dreamweaver CS4"
instead of:
Adobe/Dreamweaver CS4/en_US/Configuration/
use this for CS5
Adobe/Dreamweaver CS5/en_US/Configuration/
or for CS5.5:
Adobe/Dreamweaver CS5.5/en_US/Configuration/
Roxana
One problem is, that in Mac OS Lion the user library is a hidden file.
It is accessible when clicking on the go menu while holding down the option key.
rmlee139451
Thanks. I did realize to substitute cs5 for cs4,and I did look at the hidden files in Library, but I still have no MacFileCache.dat in the Adobe folder. Any other thoughts? Thanks gain.
it is possible that the cache file has not been created yet. if it does not exist in that folder, Dreamweaver hasn't created it yet.
