eCart Add to Cart Product Options Errors
Thread began 2/09/2012 2:49 pm by toni272059 | Last modified 2/13/2012 1:04 pm by Jason Byrnes | 4922 views | 13 replies |
toni272059
I have been thru the Product Options tutorial several times.
So far I have managed to create a product_detail page that successfully shows different Color options specific to a product and a second option Plain or With Embroidery. With Embroidery would add $15 to item price. When I go thru the steps to search for an item, view its detail page and select the 2 options everything works, no error messages.
Problems begin when I select Add to Cart button. Page does not redirect and error message shows
Notice: Undefined index: eCart1_1_Color_Add in /Users/tonimills/Sites/Boomerang_Needleworks/product_detail.php on line 121
I have checked the various recordsets against the tutorial numerous times and cannot identify what it is looking for.
I also checked the eCart Object and checked the column settings and calculations.
And the Add to Cart bindings
If I manually open the shopping cart page cart.php the item has been added. However there are no results showing for the color or embroidery option selections. Also, no $15 price increase.
I did add fields to the cart.php repeat region
<?php echo $eCart1->DisplayInfo("Embroidery"); ?>
<?php echo $eCart1->DisplayInfo("Color"); ?>
I am attaching the detail_page and cart php files and the eCart object php
Thanks in advance for your help!
Archive.1.zip
your page has 3 different form in it, one for each of the elements, quantity, color, and embroidery, not sure where the extra form tags came form, but there should only be one from with all the elements in the same form. When the form is submitted, it is not sending the value for the color or embroidery because those elements belong to a different form then the add to cart button.
toni272059
product_detail.php
OK, so I put the three elements into one <form> and that stopped the error message. However it did not take me to the cart.php page. I checked both redirects in the eCart Add from Recordset and both on the General and Bindings screens I entered Redirect to cart.php
Now when I manually go to cart.php the item has been added and the embroidery fee added with a line of text "Embroidery: Embroidery ($15)". For the color, there is just a number which I worked out is the ProductOptionID from the productoptions table of the database.
Screen grab attached.
How do I change it so the actual color is displayed? In the case of the Dog Leash: Blue, the Market Bag Set: Navy Blue and the iPad Briefcase: Black.
My next challenge is to only have options show if they are available for a specific product. For instance Embroidery is not available on everything and some products only come in one color.
Screen grabs attached showing the Long Bungee Dog Leash only comes in Blue and does not offer Embroidery.
Some guidance on how to achieve that on the detail page would be appreciated. Maybe there is a tutorial somewhere?
see the product options with eCart tutorial on the eCart support page.
toni272059
I have, that is what I was using to get to where I am now!
you need to create a recordset that will query the productoptions table to return the color and embroidery options fro the current product. Then use the Show Region behavior to only show the option elements if the recordset is not empty.
toni272059
I created recordsets for the color and embroidery options using the eCart Product Options tutorial. They correctly show the specific options available for each product on the detail_page and the price increase for Embroidery is successfully added on the Cart page.
I added the Show Region behavior if recordset not empty to the Embroidery Option and that is now working. Thank you!
Still having trouble with:
1. Redirect to Cart
The Add to Cart button on the detail_page is not redirecting to the Cart, though it is adding items to the Cart. I have to manually go to the Cart page to see the changes. I have checked the "eCart Add from Recordset" and it shows redirect to cart.php in both General and Bindings.
2. Option Name for Color on Shopping Cart page
On the cart page the Embroidery OptionName shows in the line item correctly, as in "Embroidery $15", or "Plain, no Embroidery". However the Color is showing the ProductOptionID not the OptionName from the database table
Should the eCart Add to Button Binding for Color have a default value? Screen grab attached. There is no reference to it in the tutorial, just to make Updatable as select list
1) could be a php error occurring, add the following code at line 1 of the page to turn error reporting on:
error_reporting
(E_ALL);
2) does the color effect price? or only embroidery? if the color does not effect price, set the color select list to use the color name as the value.
toni272059
I added the error coding and there was no result when I clicked Add to Cart. And still no redirect. I have checked the eCart Add from Recordset yet again and in both places (General and Bindings) the redirect value is set to cart.php which is in the same directory as the detail_page.php
As for the Color OptionName showing instead of the ProductOptionID. I think I followed correctly, see manually changed code noted below. The correct name is now showing in the shopping cart. I did not open and change any recordsets or server behaviors.
This is the code from the detail page for the color select list
<select name="eCart1_1_Color_Add">
<option value="" selected <?php if (!(strcmp("", $row_rsColor['OptionName']))) {echo "selected=\"selected\"";} ?>>Select Color</option>
do {
<option value="<?php echo $row_rsColor['NOTE:changed ProductOptionID to OptionName']?>"<?php if (!(strcmp($row_rsColor['ProductOptionID'], $row_rsColor['OptionName']))) {echo "selected=\"selected\"";} ?>><?php echo $row_rsColor['OptionName']?></option>
} while ($row_rsColor = mysql_fetch_assoc($rsColor));
$rows = mysql_num_rows($rsColor);
if($rows > 0) {
mysql_data_seek($rsColor, 0);
$row_rsColor = mysql_fetch_assoc($rsColor);
</select>
for the select list, yes, that is the correct change. for the redirect, send a copy of the latest page, and a link where i can see the problem.
