How do I edit page?
Thread begun 2/09/2012 12:42 pm by tangosdad | Last modified 2/09/2012 2:47 pm by tangosdad | 3616 views | 4 replies |
tangosdad
How do I edit page?
Once I have set up a page with CSS Sculptor, how do I reenter CSS Sculptor to make a change to the layout?
CSS Sculptor is a layout creation tool, it is not reentrant.
you could save the layout as a preset, then when you start css sculptor again, you can select he saved preset to make changes to the preset
tangosdad
Wow, this is a major limitation. Are there any plans to make it reentrant? I use another tool for this and I can edit pages I have created with it. Extremely nice although the tool has limitations. Thing is you guys are WAY better than those folks and I would love to see you knock it out of the park with a fully functional CSS Layout Editor tool. Any chance you could add this to the wish list, although I gotta believe it's already on it! :-)
If you save the layout as a preset, they you can recreate your layout using the preset as a starting point. you can then make changes to the preset and overwrite your existing layout.
tangosdad
Ok so the answer is no then. You are not considering having functionality as I outlined.
And btw, doing as you suggest and saving the preset, then using that preset creates a new page. I then have to copy over any content that I have added to the original page to the new page. This is not at all what I was wanting to do.
But fair enough, if you are not considering adding functionality as I explained then so be it.
