Using single registration for site members and phpbb
Thread began 2/07/2012 10:35 am by Jared Lui | Last modified 2/07/2012 1:00 pm by Jason Byrnes | 12793 views | 2 replies |
Jared Lui
I have read countless post both on this forum and on phpbb forums which are all several years old and am not coming up with a workable answer.
I am trying to use my simple WA registration form for the members side of a website to simultaneously register the same user on phpbb.
I can successfully get all of the information I need during the registration process into the phpbb database except for the password (i can get a password but it's the wrong encryption).
Phpbb, Drupal, Wordpress, etc. have all gone to using phpass encryption. I have downloaded the source file as well as a test file and ran the test on my server with no issues. I am including both at the bottom of this post.
My issue is that I do not know how to call this using the insert record extension. I assumed that was all I had to do but I am no longer sure. Does anyone have any experience with this or have any ideas how to proceed.
All help is appreciated.
PasswordHash.php
# Portable PHP password hashing framework.
# Version 0.3 / genuine.
# Written by Solar Designer <solar at openwall.com> in 2004-2006 and placed in
# the public domain. Revised in subsequent years, still public domain.
# There's absolutely no warranty.
# The homepage URL for this framework is:
# phpass/
# Please be sure to update the Version line if you edit this file in any way.
# It is suggested that you leave the main version number intact, but indicate
# your project name (after the slash) and add your own revision information.
# Please do not change the "private" password hashing method implemented in
# here, thereby making your hashes incompatible. However, if you must, please
# change the hash type identifier (the "$P$") to something different.
# Obviously, since this code is in the public domain, the above are not
# requirements (there can be none), but merely suggestions.
class PasswordHash {
var $itoa64;
var $iteration_count_log2;
var $portable_hashes;
var $random_state;
function PasswordHash($iteration_count_log2, $portable_hashes)
$this->itoa64 = './0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz';
if ($iteration_count_log2 < 4 || $iteration_count_log2 > 31)
$iteration_count_log2 = 8;
$this->iteration_count_log2 = $iteration_count_log2;
$this->portable_hashes = $portable_hashes;
$this->random_state = microtime();
if (function_exists('getmypid'))
$this->random_state .= getmypid();
function get_random_bytes($count)
$output = '';
if (is_readable('/dev/urandom') &&
($fh = @fopen('/dev/urandom', 'rb'))) {
$output = fread($fh, $count);
fclose($fh);
if (strlen($output) < $count) {
$output = '';
for ($i = 0; $i < $count; $i += 16) {
md5(microtime() . $this->random_state);
$output .=
pack('H*', md5($this->random_state));
$output = substr($output, 0, $count);
return $output;
function encode64($input, $count)
$output = '';
$i = 0;
do {
$value = ord($input[$i++]);
$output .= $this->itoa64[$value & 0x3f];
if ($i < $count)
$value |= ord($input[$i]) << 8;
$output .= $this->itoa64[($value >> 6) & 0x3f];
if ($i++ >= $count)
break;
if ($i < $count)
$value |= ord($input[$i]) << 16;
$output .= $this->itoa64[($value >> 12) & 0x3f];
if ($i++ >= $count)
break;
$output .= $this->itoa64[($value >> 18) & 0x3f];
} while ($i < $count);
return $output;
function gensalt_private($input)
$output = '$H$';
$output .= $this->itoa64[min($this->iteration_count_log2 +
((PHP_VERSION >= '5') ? 5 : 3), 30)];
$output .= $this->encode64($input, 6);
return $output;
function crypt_private($password, $setting)
$output = '*0';
if (substr($setting, 0, 2) == $output)
$output = '*1';
$id = substr($setting, 0, 3);
# We use "$P$", phpBB3 uses "$H$" for the same thing
if ($id != '$H$' && $id != '$H$')
return $output;
$count_log2 = strpos($this->itoa64, $setting[3]);
if ($count_log2 < 7 || $count_log2 > 30)
return $output;
$count = 1 << $count_log2;
$salt = substr($setting, 4, 8);
if (strlen($salt) != 8)
return $output;
# We're kind of forced to use MD5 here since it's the only
# cryptographic primitive available in all versions of PHP
# currently in use. To implement our own low-level crypto
# in PHP would result in much worse performance and
# consequently in lower iteration counts and hashes that are
# quicker to crack (by non-PHP code).
if (PHP_VERSION >= '5') {
$hash = md5($salt . $password, TRUE);
do {
$hash = md5($hash . $password, TRUE);
} while (--$count);
} else {
$hash = pack('H*', md5($salt . $password));
do {
$hash = pack('H*', md5($hash . $password));
} while (--$count);
$output = substr($setting, 0, 12);
$output .= $this->encode64($hash, 16);
return $output;
function gensalt_extended($input)
$count_log2 = min($this->iteration_count_log2 + 8, 24);
# This should be odd to not reveal weak DES keys, and the
# maximum valid value is (2**24 - 1) which is odd anyway.
$count = (1 << $count_log2) - 1;
$output = '_';
$output .= $this->itoa64[$count & 0x3f];
$output .= $this->itoa64[($count >> 6) & 0x3f];
$output .= $this->itoa64[($count >> 12) & 0x3f];
$output .= $this->itoa64[($count >> 18) & 0x3f];
$output .= $this->encode64($input, 3);
return $output;
function gensalt_blowfish($input)
# This one needs to use a different order of characters and a
# different encoding scheme from the one in encode64() above.
# We care because the last character in our encoded string will
# only represent 2 bits. While two known implementations of
# bcrypt will happily accept and correct a salt string which
# has the 4 unused bits set to non-zero, we do not want to take
# chances and we also do not want to waste an additional byte
# of entropy.
$itoa64 = './ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789';
$output = '$2a$';
$output .= chr(ord('0') + $this->iteration_count_log2 / 10);
$output .= chr(ord('0') + $this->iteration_count_log2 % 10);
$output .= '$';
$i = 0;
do {
$c1 = ord($input[$i++]);
$output .= $itoa64[$c1 >> 2];
$c1 = ($c1 & 0x03) << 4;
if ($i >= 16) {
$output .= $itoa64[$c1];
break;
$c2 = ord($input[$i++]);
$c1 |= $c2 >> 4;
$c1 = ($c2 & 0x0f) << 2;
$c1 |= $c2 >> 6;
$output .= $itoa64[$c2 & 0x3f];
} while (1);
return $output;
function HashPassword($password)
$random = '';
if (CRYPT_BLOWFISH == 1 && !$this->portable_hashes) {
$random = $this->get_random_bytes(16);
$hash =
crypt($password, $this->gensalt_blowfish($random));
if (strlen($hash) == 60)
return $hash;
if (CRYPT_EXT_DES == 1 && !$this->portable_hashes) {
if (strlen($random) < 3)
$random = $this->get_random_bytes(3);
$hash =
crypt($password, $this->gensalt_extended($random));
if (strlen($hash) == 20)
return $hash;
if (strlen($random) < 6)
$random = $this->get_random_bytes(6);
$hash =
$this->crypt_private($password,
$this->gensalt_private($random));
if (strlen($hash) == 34)
return $hash;
# Returning '*' on error is safe here, but would _not_ be safe
# in a crypt(3)-like function used _both_ for generating new
# hashes and for validating passwords against existing hashes.
return '*';
function CheckPassword($password, $stored_hash)
$hash = $this->crypt_private($password, $stored_hash);
if ($hash[0] == '*')
$hash = crypt($password, $stored_hash);
return $hash == $stored_hash;
Jared Lui
Here is the test.php
# This is a test program for the portable PHP password hashing framework.
# Written by Solar Designer and placed in the public domain.
# See PasswordHash.php for more information.
require 'PasswordHash.php';
header('Content-type: text/plain');
$ok = 0;
# Try to use stronger but system-specific hashes, with a possible fallback to
# the weaker portable hashes.
$t_hasher = new PasswordHash(8, FALSE);
$correct = 'test12345';
$hash = $t_hasher->HashPassword($correct);
print 'Hash: ' . $hash . "\n";
$check = $t_hasher->CheckPassword($correct, $hash);
if ($check) $ok++;
print "Check correct: '" . $check . "' (should be '1')\n";
$wrong = 'test12346';
$check = $t_hasher->CheckPassword($wrong, $hash);
if (!$check) $ok++;
print "Check wrong: '" . $check . "' (should be '0' or '')\n";
unset($t_hasher);
# Force the use of weaker portable hashes.
$t_hasher = new PasswordHash(8, TRUE);
if ($check) $ok++;
if (!$check) $ok++;
# A correct portable hash for 'test12345'.
# Please note the use of single quotes to ensure that the dollar signs will
# be interpreted literally. Of course, a real application making use of the
# framework won't store password hashes within a PHP source file anyway.
# We only do this for testing.
$hash = '$P$9IQRaTwmfeRo7ud9Fh4E2PdI0S3r.L0';
if ($check) $ok++;
if (!$check) $ok++;
if ($ok == 6)
print "All tests have PASSED\n";
else
print "Some tests have FAILED\n";
this is not supported using data assist.
If you need assistance using this, i would suggest signing up for a premiere ticket appointment where we could work with you in a one on on screen sharing session to implement this.
