Date always 01-01-1970
Thread began 2/07/2012 8:51 am by gary.brett434358 | Last modified 2/14/2012 2:55 am by gary.brett434358 | 20684 views | 35 replies |
gary.brett434358
Hi, this is most probably not an issue with with DA but has anyone come across this before, I usually work with SQL & asp so not sure?
I have fields which users can use a datepicker to enter a date. At top of each php page I have the following to allow uk format input but insert to db in its recognised values:
if(isset($_POST['ContactDOB']) && $_POST['ContactDOB'] != "") {
$_POST['ContactDOB'] = date("Y-m-d", strtotime($_POST['ContactDOB']));
if(isset($_POST['StatusAppDate']) && $_POST['StatusAppDate'] != "") {
$_POST['StatusAppDate'] = date("Y-m-d", strtotime($_POST['StatusAppDate']));
if(isset($_POST['StatusActiveDate']) && $_POST['StatusActiveDate'] != "") {
$_POST['StatusActiveDate'] = date("Y-m-d", strtotime($_POST['StatusActiveDate']));
if(isset($_POST['ContactCompDate']) && $_POST['ContactCompDate'] != "") {
$_POST['ContactCompDate'] = date("Y-m-d", strtotime($_POST['ContactCompDate']));
if(isset($_POST['StatusNPWDate']) && $_POST['StatusNPWDate'] != "") {
$_POST['StatusNPWDate'] = date("Y-m-d", strtotime($_POST['StatusNPWDate']));
However all fields dont have date selected write 01-01-1970 into table, is this normal? I have checked table and its set as 'Date', 'NULL' & allow NULL is checked.
Ian S
Dave has written a nice little function to create dates from a form POST.
showthread.php?t=17864
Cheers
Ian
gary.brett434358
Thanks for your post Ian,
I removed my original code in the head section as posted above and inserted Dave's code. Then on the 3 date fields in my form I appended the code as such:
<?php echo ((isset($_POST["StatusActiveDate"]))?i8_formatUKDateMySQL($_POST["StatusActiveDate"]):""); ?>
<?php echo ((isset($_POST["StatusCompDate"]))?i8_formatUKDateMySQL($_POST["StatusCompDate"]):""); ?>
<?php echo ((isset($_POST["StatusNPWDate"]))?i8_formatUKDateMySQL($_POST["StatusNPWDate"]):""); ?>
When I now open the form and insert date or if the fields are left blank it inserts '0000-00-00' into each field in the database, in the details page however it just returns 01-01-1970!!
Any ideas where I am going wrong, I really need the fields to be blank if nothing is entered, yet accept uk value if datepicker is used?
Insert page attached if it helps anyone.
Thanks again
tblcases_Insert_Direct.zip
Ian S
They way that I handle dates, using a transform function like Daves is to put them into Session Values and then insert the session values into the database. There might be a neater way than this though....
Here is a quick example:
if (isset($_POST["BT_Add"])) { // Trigger
if ($_POST['dateup'] != '') {
$_SESSION['var_update'] = formatUKDateMySQL($_POST['update']);
} else {
$_SESSION['var_update'] = Null;
if ($_POST['datedown'] != '') {
$_SESSION['var_downdate'] = formatUKDateMySQL($_POST['downdate']);
} else {
$_SESSION['var_downdate'] = Null;
Basically the code above checks to see if the date field is populated. If it is it transforms the date to UK and if not then it passes a null value. That way I get either a UK date or blank field.
Hope this helps?
Cheers
Ian
gary.brett434358
Hi Ian, thanks again for the help.
Do you use your code on an insert/update page? Do I simply need to add your code to top of the page and nowhere else?
Using Dave's code I had to add code to values as previous post?
gary.brett434358
Hi again Ian, just tried putting your code at top of page and removed the i8 code from insert behaviour values. Do I need to reference the fieldnames anywhere?
This still inserts 0000-00-00 into MySQL and displays it as 01-01-1970 on the details page? As you can probably tell I know nothing of php/mysql, normally work in SQL & asp which seems straightforward right now!
insert.php
} else {
} else {
Example date field
<input type="text" name="StatusActiveDate" id="StatusActiveDate" value="Set Live Date" size="32" class="datepicker" /
details.php
[code]
<tr> <td><h6>Case Active:</h6></td>
<td><?php echo(date("d-m-Y", strtotime($row_WADAtblcases['StatusActiveDate']))); ?></td>
</tr>
<tr> <td><h6>Case Completed:</h6></td>
<td><?php echo(date("d-m-Y", strtotime($row_WADAtblcases['StatusCompDate']))); ?></td>
</tr>
<tr> <td><h6>Case NPW:</h6></td>
<td><?php echo(date("d-m-Y", strtotime($row_WADAtblcases['StatusNPWDate']))); ?></td>
</tr>
[code]
Ian S
You will still need Daves code (or equivalent).
If you are using Daves code you need to put my code between your insert / update behaviour and Daves code.
So with Daves code you would use
if (isset($_POST["BT_Add"])) { // Trigger assuming that your submit button is called BT_Add
if ($_POST['StatusActiveDate'] != '') {
$_SESSION['StatusActiveDate'] = i8_formatUKDateMySQL($_POST['StatusActiveDate']);
} else {
$_SESSION['StatusActiveDate'] = Null;
And then the values that you would pass to the database are stored in the Session variables.
Cheers
Ian
gary.brett434358
Thanks again Ian, its becoming a long day! My form button is set via a js file so I don't have a submit button name as such?
On my insert page I have now added Daves function above your code, 1 each for the date fields on my page. This still inserts 0000-00-00 into database rather than null and still displays 01-01-1970 on results page.
Is this because I have no submit button to reference do you think?
function i8_formatUKDateMySQL($date) {
$d = str_replace(" ","",$date);
$d = explode('/', $date);
$d = $d[2].'-'.$d[1].'-'.$d[0];
return $d;
if (isset($_POST["doc_upload"])) { // Trigger assuming that your submit button is called BT_Add
} else {
if ($_POST['StatusCompDate'] != '') {
$_SESSION['StatusCompDate'] = i8_formatUKDateMySQL($_POST['StatusCompDate']);
} else {
$_SESSION['StatusCompDate'] = Null;
Thanks again..
Ian S
I think it could well be because the PHP code is set to run if the form is submitted via a post.
Can you try it with a standard form POST and see if that works?
gary.brett434358
Originally Said By: Ian S
Hi Ian, the form was already POST, what I have done as a test in use a submit button called insert. All form data is submitted as usual but the date field I added a value to & the date fields left blank were written as 0000-00-00 again.
On the update.php page if I select a date on 1 field it does write it into the db & I can clear the 2 other date fields by delete 01-01-1970, this works fine.
Just to clarify the code on the update.php page that inserts the correct date is
This is so confusing!
